Electricski22
- Texas
- Electrician
I have a 200amp breaker outside which is where the ground electrode is landed and then a 3 wire SE cable is ran inside to a main lug panel. Am wanting to upgrade this panel because it is a federal pacific. If I install a new panel would I be required to run a 4 wire SE cable and separate neutral and grounds or would the 3 wire SE cable currently installed be okay and bond the neutrals and grounds?
