What is everyone’s interpretation on 240.24(D)?
Here is the code verbatim:
Not in vicinity of easily ignitable material. Overcurrent devices shall not be located in the vicinity of easily ignitable material, such as in clothes closets.
I’m in the beginning stages of wiring a 17k sq/ft mansion. Being the type of house it is the panels need to be fairly hidden, not in hallways or bedrooms where they will be seen all the time. I thought I had the perfect spot to hide them in, a closet off of one of the laundry rooms. The closet is approximately 80 sq/ft. The plans show hanging racks on one side, I wanted to put my panels on the opposite wall which is 6’ away. Now I’m being told I can’t because of this code and that being a closet. The NEC does not define vicinity, but we all know it goes into working space about panels. In my mind as long as the working space is maintained that should be considered not in the vicinity and therefore should be able to put a panel in there. Obviously I would never put a panel in a standard clothes closet with bifold doors. But are you really gonna tell me that I couldn’t put one in this closet, or even better yet the master closet that is probably 500sq ft alone just because there are some clothes in there? Furthermore I don’t believe this code is saying you can’t put a panel in a closet, the way it is worded a clothes closet to me seems like an example. There are easily ignitable materials all around a house, garages especially, but no one has ever told you you can’t put a panel in a garage have they?
