PMichael944
- PA
- Electrician
Reaching out for as much input as possible. Working for an adhesives production company. Company makes and packages adhesives and such but not really important to question beyond that. The initial processing begins with mixing, for which we have multiple industrial sized mixers. The one in question, is a 500G, 3 phase, 480v 250A 60HZ mixer.
From the main electrical panel power is run to electrical cabinet in mech room, then to mixer which has its own control panel on machine also. (I’m not the best at explaining things but gonna try really hard to give mental picture) So the electrical cabinet, power comes in to 250A disconnect and from there directly out to two main contractors, each having its own thermal overload. The contractors basically control two seperate function of the mixer. Dispersion and planetary. All wiring through is properly sized. Here’s where fun begins.
When I first started, they had been having issues with dispersion side overheating and tripping out overload. Process of determining why, I eventually replaced leads from d/c to contactor making them exact length and torquing connections. Finally seemed to solve issue.
Friday, the planetary contactor side overheated (b and c phases temp when shot it were 210-250 degrees and A phase read at 417 degrees). Wires had begun to disintegrate . Contactor became welded closed. Niether the d/c nor overload tripped.
The machine was manually shut down immediately at that point.
I am just basically looking for any ideas from anybody as to what thoughts are on what would cause this. I just do not want to overlook anything or miss anything that could allow to happen again.
Thank You
Thank You
