electrofelon
- Cherry Valley NY, Seattle, WA
- Electrician
As long as Ultility companies only supply one high voltage lead to thier thousands of distribution transformers this will be a potential problem.
I would not say that is necessarily a SWER. It seems perfectly reasonable to refer to a transformer fed L-N from an MGN to have "only one high voltage lead"That would be a singe wire earth return and is never used in populated areas. The utility uses a common conductor as the neutral for both their high voltage distribution and the secondary of the transformers that supply power to their customers.
