Wondering the right way to model this, I was told that the relay must be placed in a way so that it can open/close the switch, otherwise it's just a passive device.
But I don't know what that means in context of my model exactly.
Is this correct (snapshot of SKM below)? I placed the relay after the switch and before the fuse, which is how it seems to be in the actual switchboard. The switchboard in real life has an incoming line-side connection, feeding the switch, which appears to feed the fuse, which then appears to feed the switchboard bus. The relays appear to sit in between the fuse and switch.
