Familytechsupport
- Texas
- Retired engineer
This weekend a family member charged their EV from a 30 amp dryer plug but forgot to set the charger to limit things to 24 amps so it ran in 32 amp mode. Everyone understands that this was bad and can't happen again.
The charging lasted for about 3.5 hours and the breaker never popped. The charging showed a peak power of 7400W so that implies max current was close to 31 amps. The plug was quite warm to the touch, but not so warm that it couldn't be handled with a bare hand. There were no other effects seen. There was not way to observe the in-wall wiring of the circuit. Air temperature was in the 75F range.
The question being asked is if we should assume there is hidden damage in the circuit. I know nobody can answer this definitively, but I'm trying to figure out how worried to be.
