Installing multiple Waterless Toilets at Remote Facilities. The small buildings have a small room that I will make into a Toilet Only Rest Room.
The entire building does not have running water at all. Zero plumbing in the building. There is nothing else inside the Rest Room with the Incinolet Waterless Toilet. The toilet is essentially a large stainless steel can with a large heating element and blower fan - See link below.
I will be installing a dedicated 120VAC 20Amp Circuit to the outlet as per the manufacture's requirement.
The toilet has a cord with a 20 Amp Plug. Will not be Hard-Wiring the toilet.
Does the 20 Amp outlet for this Incinolet Toilet need to be GFCI Protected ?
incinolet.com
YOUR CLEAN, ECO-FRIENDLY SOLUTION »
Get your YOUR CLEAN, ECO-FRIENDLY SOLUTION - Replacement and Maintenance Parts for the Incinolet Incinerating Toilet.
incinolet.com
