dtdarrah7
 - San Antonio
 - Electrical Engineer
Grounding & Bonding for a 24V DC Hydroponics Setup - Needed Input
Hello all,
I am designing an electrical system for my Senior Design Project, which powers a hydroponics setup, and I’d appreciate some guidance on grounding and bonding.
System Overview:
- Power Source: 120V AC to 24V DC charger (Victron Blue Smart IP22, 24V 16A x2 in parallel) acting as a power supply and battery charger (includes backflow prevention).
 - DC Bus:Powered by the charger, distributing power to three circuits:
- 24V 100Ah LiFePO₄ battery (backup power source).
 - 24V DC to 120V AC inverter (powers two sump pumps, controlled via hi-low sensors).
 - 24V DC to 5V DC buck converter (powers a Raspberry Pi for monitoring).
 - Operation: Runs on building power under normal conditions; if power is lost, the system islands and supplies loads via the battery + inverter.
Grounding & Bonding Questions:
- DC Panel (Metallic Enclosure): Should the chassis be bonded to the building grounding system?
 - Battery Negative Terminal: Does it need to be bonded to the building ground, or should it remain floating?
 - Inverter Grounding Terminal: Does this need to be bonded to the building grounding system?
 - Hydroponics Water Tanks: Since the water has high electrolytic content, should I install grounding electrodes in the tanks?
My Thoughts So Far:
- I believe the DC panel chassis should be bonded to the building ground for touch potential safety.
 - I am reconsidering bonding the battery negative to building ground, as my DC panel is metallic, and I want to create a path back to the source for my OCP to work.
 - NEC compliance is a priority, but since my system is below 60V DC, I’m trying to determine the best approach for grounding while maintaining safe operation.
Thanks!
