Alan2025
- East Bay San Francisco
- Electrician retired
I am building an addition to a cabin that I own in Idaho. I am adding a detached garage with a living unit above. The cabin is 860 square feet with a 300 square foot loft. The addition will be 630 sq. ft. garage (unheated) + 630 living space sq. ft.. Both cabin and garage/living unit will be ALL electric.
I want to make sure that I figure my loads correctly. Another set of eyes, please.
Cabin load -
Baseboard heaters 3-1500 w, 1-1000w, 1-500w, Hot Water Heater-3,800w, Refrigerator 20 cu ft. , LED lighting and 20 amp receptacles (per code)
Garage/living space addition load-
Baseboard heaters- 2-1500w, 1-1000w, 2-500w, Hot Water Heater-3,800w, Refrigerator 20 cu ft. , LED lighting and 20 amp receptacles (per code)
I have a 200 amp service panel that feeds a 200 amp sub-panel. I am thinking of replacing the 200 amp sub-panel main with a 100 amp breaker (I want to avoid coming off the sub panel due to access issues. It can be done but I would prefer coming off the service panel.
From the service I can feed the sub-panel in the garage with a 70 amp breaker or I can use a sub feed lug to a 100 amp sub-panel. Everything is Square D.
Cabin load -
