Jimmy7
- Boston, MA
- Electrician
I was asked to replace a faulty 240 volt electric heat wall mounted thermostat, and everything is existing. The heat is fed with 12-2 romex on a 20 amp double pole breaker. There are two 8’ baseboard heaters being controlled by this wall mounted thermostat. Everything is existing and old and has been painted over numerous times. I couldn’t find a wattage on the baseboards, but isn’t it typically 250 watts per foot? If so, wouldn’t this be 16’ x 250 watts =4000 watts, and shouldn’t the breaker only be loaded to 80% (240v x 16 amps 3840 watts)? Instead of 240v x 20 amps= 4800 watts? If I’m correct how would you handle this with a homeowner?
