I would leave a wire behind and drill out the metal for a box after the metal is installed. I would also put up some blocking so I had something to secure the box to.What's the best way to rough in boxes behind ribbed metal walls. Has to be in conduit or flex, is the best way to leave the flex a little long and just adjust the boxes as they are putting up the tin so you don't line up on a rib?
Wood frame building. Specs require the boxes to be recessed in the walls unfortunentlyI would leave a wire behind and drill out the metal for a box after the metal is installed. I would also put up some blocking so I had something to secure the box to.
Is this like a steel building or traditional wood framing with metal siding?
I would mark out the locations, put a block in to fasten an octagon box to and leave a wire there. Drill the hole after the metal is up, Mount the box.Wood frame building. Specs require the boxes to be recessed in the walls unfortunently
Yeah might be a good idea. Or perhaps could have the carpenters make you some out of cedar. depends on the profile of the metal. I was assuming with my comments that there was a flat spot large enough for the fixture canopy, maybe that's not the case.Vinyl siding blocks?
I believe the OP is talking about receptacle boxes, not ceiling boxes.I would mark out the locations, put a block in to fasten an octagon box to and leave a wire there.
I don't think he means outside either. I think it is a metal building with corrugated steel. He is roughing it in and the receptacles are to be recessed. He wants to know how to avoid the ribs in the steel when putting in the boxes. IMO, he is going to have to work with the installer of the metal siding. May have to put in some blocking to mount the receptacle boxes to. Or maybe some Caddy mounts for the boxes.Yeah could be, don't know why I assumed fixture boxes. If for outlets, and assuming this is outside I would probably use an Arlington inbox.
