I got asked if I would take on a residential build that was started by another contractor.
It’s roughed in and has been approved for cover.
As I look through the work I’m noticing things.
- Bored holes thru studs that are in some places less than an inch from the face without guard plates.
- A number of nail on boxes that exceed volume fill.
18 cu in single gang with 4 14/2 and a device.
- NM cable through holes that are caulked.
3-14/2 with ground
1- 14/3 with ground
- 8/2 and 10/3 NM cables stapled to the bottom of the floor joists in the basement.
List goes on.
I know this is petty stuff but do I contact the inspector and raise the issues?
He will be the one finaling the job when I finish it.
3-14/2 with ground
1- 14/3 with ground
List goes on.
