SceneryDriver
- NJ
- Electrical and Automation Designer
The conductors for my well run into the basement in the same type of poly pipe that the water comes through. I had to adapt the poly to Liquidtite with a silly stackup of plumbing and electrical PVC fittings and run it to a j-box on the wall when I bought the house. It was just run loose across the floor to the pressure switch. For that and many other reasons, it's a wonder the house didn't burn down before we bought it.I can confirm at my own house, and the few houses I've eyeballed for one reason or another in Maryland, it's UF (usually direct burial, I've not seen pvc) from house to the top of the well casing. From there it enters into the casing cap and is spliced to the twisted no-jacket conductors the OP is talking about.
I've never seen the twisted conductors outside the well casing or bore hole.
SceneryDriver
