Best way to organize this cable mess on the basement ceiling?
dirtynails
NJ
This mess is on the ceiling of the basement boiler room in a 4 family.
The joists are perpendicular to the cables, so I could simply use clamps and screws to lay them out all parallel on the ceiling, but I was hoping for something more elegant. suggestions? What about something like this kind of track?
There's about 10 ft of the same cables in the hallway between the boiler room door and the panel, where I'd like to put it out of sight but still accessible in case a new circuit needs to be run, so not a drywall soffit. Is there some system with snap on panels for that area? Thanks for any tips.
or a piece of 4" PVC split with a circular saw ( Be VEWWY VEWWY CAWEFUL !!! )
Now THATS in my wheelhouse! Screwing it temporarily to a 1x5 board to go against the table saw fence would work and be safe. I had no idea these improvs were ok. Hanging PVC with perfed steel tape would be easy.
That wouldn't get the hairy eyeball from an inspector???
I would worry more about that ratty (probably) overloaded 4" round in the middle of the ceiling.
Those cables you are worried about, I wouldn't spend a lot of money. Just Ty-Rap them neatly together and support them from something like a 1/2" one hole EMT strap on the ceiling with another Ty-Rap every so often.
-Hal
-Hal
Yeah, definitely over box fill, but there's no loads other than the boiler room lights on it. I guess I could easily replace it with a 21 cu in 4x4 box and be fine. There's just so much ancient wiring in my city that they seems to grandfather this stuff in. There's so many 2x3 outlet and switch boxes that are overfilled, it seems the rule rather than exception. Look at this crazy sh*t that was in the attic! No box there, just one of those cast iron rings on the gas pipe. No worries, that's all gone now.
