Hi,
I'm looking to install a Dishwasher circuit and a Appliance circuit in a kitchen.
The panel is a 63 yr old pushmatic. (Bulldog?)
Does pushmatic make a arcfault breaker? I can't find one if they do.
Can I install regular 20 amp 120 volt breakers and go through arc fault deadfront devices instead the arcfault breakers at the panel location?
If not, would installing a subpanel with the arcfault breakers be acceptable? ( provided I can find a two pole 50 or 60 amp pushmatic breaker)
Thank you
Thank you
