Jpflex
Electrician big leagues
- Victorville
- Electrician commercial and residential
You can solve for the unknown power factor using watts and dividing by voltage x amperes for single phase howerIMHO, less thermal imaging reports would follow overheated wire if more electricians paid attention to 220.18 for inductive ballast & motor loads, where current rises with voltage drop.
The equation wants Amps, reminding electricians Watts is useless without knowing Power Factor.
Power factor changes/ varies depending on which loads are on during testing?
