PanelGuy1315
- Louisville
- Electrical Designer
Hello everyone,
We have a situation where we've run a single set of 600kcmil conductors from a 400A breaker in an iline panel to a 400A MLO panel. We are finding out the breaker and the MLO panel are both set up for a parallel feed with max 500kcmil connections.
I think there are options to buy different lug kits for both ends here but wanted to see if the Burndy pin connectors are also an option? Or if anyone else has a similar product or solution.
							 www.hubbell.com
					www.hubbell.com
YE36P350X150FX, Copper Compression Pin Adapter, 600/500 kcmil Cu | YE36P350X150FX | Burndy
Type YE-P copper compression adapters are designed for reliable termination of copper conductor when the current capacity of the conductor is downsized, but larger conductor is utilized. Typical applications are for voltage drop protection when oversized conductors are used or flex conductor is...
