In Article 240.21 C(6) it states as one of the conditions that "secondary conductors shall be terminated on a single circuit breaker or set of fuses". Can I use the Main Breaker on the panelboard it will feed as the single circuit breaker? Or does it have to be separate from the panelboard as the panel board will feed multiple different lighting loads? (We are assuming the rest of the requirements are met)
In Article 240.21 C(1) Industrial installation it says "if all overcurrent devices are grouped" what does that mean?
Another question would be is there any instance where a transformer cant feed a general Panel as long as the secondary requirements are met?
Last question can I be over 25ft if I put a disconnect in line with the secondary conductors before it gets to the panel?
Let me know what you think thank you for your time
