What is the correct answer here?
In case you cannot see the pic clearly for value 1 dispute, a parallel set of 4/0 feeders enter the top cabinet and terminate on lugs on the same side of the enclosure wall (top of enclosure shown)
Therefore we use table 312.6 A
A 4/0 parallel conductor if 2 wires per terminal (for parallel?) Shows 6 inches os space needed but not 7 abd 1/2 inches on the second values shown by nec unless they meant terminating the wires at the bottom as opposed to what the picture shows?
