LarryFine
- Henrico County, VA
- Electrical Contractor
You're welcome.. . . atleast that does cut down on cost of an additional disconnect and 3 fuses.
What about Burkina Faso?South Africa operates on a standard voltage of 230 volts at a frequency of 50 Hz (AC).
Thank you as well.You're welcome.![]()
Similar but shall we stick to original topic ?What about Burkina Faso?
Was that South Africa?Similar but shall we stick to original topic ?
Nope. Now shall we stick to the original topic?Was that South Africa?
Go ahead. You mentioned South Africa so I figured we had shifted gears to countries of the world.Nope. Now shall we stick to the original topic?
It was your reference to Europe I commented on. There are others similar - I picked one.Go ahead. You mentioned South Africa so I figured we had shifted gears to countries of the world.
Thank you for the help. Never occurred to me that it’s the maximum and we could have gone lower. Since I already stock the material I was just going to wire everything with #6 THHN anyhow but atleast that does cut down on cost of an additional disconnect and 3 fuses.
What did South Africa have to do with Europe?It was your reference to Europe I commented on. There are others similar - I picked one.
No big deal. Stick with the 380Vac....
Like I said I just picked one outside EU. Would work just as well for New Zealand, Sri Lanka etc......................What did South Africa have to do with Europe?
Yeah. That stuff can be pretty tough. I can understand why you'd be confused.Like I said I just picked one outside EU. Would work just as well for New Zealand, Sri Lanka etc......................
But not 380V 60Hz.
I’m confused, about every one of your posts.Yeah. That stuff can be pretty tough. I can understand why you'd be confused.
Not confused -I have been around quite a fair bit and worked with different systems. Including 380V 60 Hz which where we were up to.Yeah. That stuff can be pretty tough. I can understand why you'd be confused.
Nothing I have said applies to this problem. I'm just having a little fun with Besoeker. Anything not 400/230 volts and 50 Hz really fries his brain so I just got ahead of him here.I’m confused, about every one of your posts.
Just come out and say what you mean.
Ha ha ha.................Nothing I have said applies to this problem. I'm just having a little fun with Besoeker. Anything not 400/230 volts and 50 Hz really fries his brain so I just got ahead of him here.
