malachi constant
- Minneapolis
I am a PE with 25 years experience, but don't yet understand a nuance here. I understand "available fault current" and the need to brace equipment with an SCCR that is higher than than the AIC. I understand how arc flash is a function of both how large the fault current is, and how long it is allowed to continue before clearing. So there are a couple basic concepts you probably don't need to walk me through.
What I don't understand is, what exactly is the SCCR getting you? I have read that for equipment with appropriate SCCR "damage may occur, but it must not present a shock hazard, fire hazard, or expel projectiles from the equipment". So say if you calculate 45.4k available fault current, you would rate the panel at 65kAIC. But then the perfect storm of a fault happens, and an arc flash event occurs. On an intuitive level I would think the SCCR would mean the equipment is built more "heavy duty" or with bussing further apart so that when the short circuit occurs it does not turn into a ball of flame. Obviously, I know, that is not how it works - the ball of flame may still be coming. So what level of safety are you getting with the increased SCCR? Is it "when the arc flash occurs the panel blows up a little bit less", or what?
I am not articulating this perfectly, but would appreciate you taking stabs at answering what you think I am asking and maybe that will help me ask it better. Thanks in advance!
