I am using 2/0 conductor 480 three phase for a compressor it is piped with rigid conduit and LFMC with grounds I didn't use fittings to pull because it is such a tight bend radius instead I used metal pull boxes. I normally bond these with the equipment ground I pull in but a co worker of mine is saying you do not have to what are your thoughts do you bond or not bond the pull box if its not a splice box?
