I work for a laboratory. We have many in-house custom-made pieces of equipment. We are doing an inspection of this equipment to be sure that it’s safe. A question came up about power cords supplying the equipment. For example, we have a wall outlet rated at 220V 30A, and have a piece of equipment plugged into it that is rated for only 5 A. We use a 14 gauge wire into a metal rack mount box. The cable enters the box through a standard compression cable clamp.
The issue at hand is trying to find the NEC codes that allow a smaller gauge wire to plug into the 30 wall outlet. Consider a lamp zip wire plugged into a 20 amp 120V outlet. Certainly doesn’t require anCertainly doesn’t require a 20 amp cable. Our local authority won’t let us use the equipment. Until we show the proper code that allows the smaller gauge wire supplying a smaller load.
any help appreciated.
Steve
Steve
