Seven-Delta-FortyOne
Goin’ Down In Flames........
- Humboldt
- EC and GC
Looking at 550.10(I)2 2020 NEC/2022 California Electrical Code
Technically this would be a feeder, as the meter is on a pole a few hundred feet away with a disconnect.
Job I’m looking at is a home standby generator install. Here is a pic of how the feeder comes into the home underneath. Is that gap standard practice?
Behind the I beam, not visible in the pic, is a 2” pvc conduit down through the floor. 550.10 states there must be provision for attaching a junction box, but doesn’t say a box is required. Is this standard connection details for a manufactured home?
I need to intercept the feeder and reroute to the ATS, and I’m looking for the best spot, and also trying to find out if that will get called on inspection.
