mtnelect
HVAC & Electrical Contractor
 - Southern California
 - Contractor, C10 & C20 - Semi Retired
"We are only pawns in the game of life"
			I get it I like my inspector there cool- but there’s been a couple were I don’t back down. It’s my money not hisIf we can also get rid of the jerk who installed it wrong to begin with, it's a deal. I agree with your sentiment, it is way too common for inspection departments to have incompetent inspectors and cause these problems.
It's only that way if the inspector and the contractor make it that way. 99% of the time, the inspector just needs to communicate properly and the EC has no issues with it. The rest is just paperwork - the inspector has to write the issue down somewhere, and the most convenient place is on the permit that is already open. Especially since the EC is normally going to be the one handling the issue. Unfortunately, inspectors who communicate properly much rarer than they should be.
I had one the other day when I found work that had been done without a permit last year while inspecting new work that was done by a licensed contractor under permit and inspection. I called the electrician and talked to him about it, told him that it wasn't necessarily his problem but it gives him the opportunity to have a bid ready and it's gonna be a major pain on everyone else if he doesn't. He was totally cool with it.
If he wasn't, now I would have to hunt down the owner, threaten court action, drag the situation out for many months and unnecessary $$$. Quite apart from the pain and suffering aspect, my time is paid for by the taxpayer, so those dollars are also unnecessarily wasted.
As others have said its a local issue, however I can tell you that locally in MD you need a certificate of occupancy (CO) to legally have the right to occupy a building, or that portion of any existing building undergoing renovations and enjoy the 'right to privacy'.We installed an EV charger. Inspector failed it saying "Service load calculation required for additional load of 60 amp EV charger. Raceway required for open conductors to surge protector( see photos in documents)."
The surge protector was installed in 2019 & passed inspection.
Load is way under just by looking at it but ok, we'll send one to him. But is he allowed to fail our EV charger inspection for something we didn't do that already passed inspection?
My husband's the Master Electrician, I do the business stuff, so I'm not super familiar with all of this...
If there wasn't construction company trailers and such nearby, you can bet that was a big reason they were there, they won't put on blinders and ignore anything not construction related they see while there though.they weren't there looking at only construction personnel, they also were looking at the Hospital itself which was the primary reason they were there.
Not really, they will inspect factory's, hospitals, distribution facilities, etc..., with no construction at all going on. They also inspect all shifts of the day and weekends. The chief of police in an NC town told me they had been inspected once.If there wasn't construction company trailers and such nearby, you can bet that was a big reason they were there, they won't put on blinders and ignore anything not construction related they see while there though.
This strikes me as unusual. I'm not sure if it was a NJ case, but someone took the inspector (not sure which code) to court for trespassing. Work was going on that was not permitted. The court decided the inspector wasn't allowed to go on a property that didn't have a permit filed with the town. Kind of crazy, but that was one court's opinion.Not really, they will inspect factory's, hospitals, distribution facilities, etc..., with no construction at all going on. They also inspect all shifts of the day and weekends. The chief of police in an NC town told me they had been inspected once.
In NC they actually had to notify the facility and meet with the representatives of the facility before the actual inspection. In the parking lot case they had done that with the hospital and the construction projects were considered covered under the notification and pre inspection meeting.This strikes me as unusual. I'm not sure if it was a NJ case, but someone took the inspector (not sure which code) to court for trespassing. Work was going on that was not permitted. The court decided the inspector wasn't allowed to go on a property that didn't have a permit filed with the town. Kind of crazy, but that was one court's opinion.
There's a fairly-well understood concept that if an officer can easily see something (like above), they don't need warrant, permit, or whatever to follow up on the violation.I know of one situation where a OSHA inspector was driving by a site on his way home and saw someone standing on a pallet on a Lull about 20' up on the side of building, he stopped and immediately sited the company.
This is covered by the plain view doctrine that holds that an offense being carried out in plain view of an enforcement officer a warrant is not required for entry nor enforcement.There were exceptions to this as in any rules. I know of one situation where a OSHA inspector was driving by a site on his way home and saw someone standing on a pallet on a Lull about 20' up on the side of building, he stopped and immediately sited the company.
I don't know, but violations are definitely on a scale. I see some existing stuff that isn't right, but isn't so dangerous that it even needs mentioning. Then there are some things that you see that are bad enough to bring up. But regardless, you have no responsibility to fix anything that isn't associated with your work.So you have a violation that at the time of original install was not compliant but you didn't do that install and it "supposedly passed an inspection". The work you are doing is in the vicinity but not directly related to the work you are doing. Should the current inspector be turning a blind eye to the presumably preexisting violation? If work was in obvious line of site and should be noticeable to the current electrician should he also be turning the blind eye to the known by him violation? I wouldn't think so to either case. How unsafe should a preexisting violation that was a violation at the presumed time of initial installation need to be before it should be corrected, or forced to be corrected?
thats interesting I'd never know this legal stuff otherwise unless I went to law school, so a 'CO' is what legally makes some 2X4's nailed together a protected 'private residence' in the legal system, if thats revoked then its just back to pile of 2X4's....or they were going to get their business license with the city and certificate of occupancy revoked.
The mortgage would still be due.thats interesting I'd never know this legal stuff otherwise unless I went to law school, so a 'CO' is what legally makes some 2X4's nailed together a protected 'private residence' in the legal system, if thats revoked then its just back to pile of 2X4's.
I understand. I still believe that said inspector will have somewhat a gut instinct that the chance of finding violations from a contractor on site will be higher than with the hospital. There possibly many OSHA inspectors that aren't even aware of some of what might be violations in the patient categories although some of that may also be somewhat parallel with department of health officials.Not really, they will inspect factory's, hospitals, distribution facilities, etc..., with no construction at all going on. They also inspect all shifts of the day and weekends. The chief of police in an NC town told me they had been inspected once.
