Hi guys
A few people mentioned you guys might help.
I'm getting a terrible buzzing through all of my guitars - on a spectrum analyzer it's centered mainly around 2.5 khz - I've ruled out everything in the house I've turned off all Breakers but one and then I've tried multiple outlets in the house and I have this one spot, where I have to record, in the middle of my recording room where I'm getting this terrible buzzing, while in other rooms, except the joining room, I don't get it at all(I've moved my setup to various rooms & outlets and using a long guitar cable, the noise still happens in the recording room. If I point my guitar humbucker right down to the floor the buzz increases dramatically. Underneath me is the basement and I found a ground wire running on the basement joists that leads to the water main and it comes from the main breaker box, and even with the mains power off in the house, the ground wire's the only thing that's admitting any EMF so those magnetic readings coming from there with my guitar plugged in and only one Outlet on in the entire house, it still buzzes in that room. It buzzes really loud exactly where this line is & it goes across another room in the house I brought the guitar in there and it buzzes dramatically when I put it to the floor there too, so it seems like magnetic interference is coming through the floor. I shielded the inside of the guitar with copper foil but I'm told magnetic interference is different than electrical Etc? (don't know). I've tried so many things I'm not sure if this is exactly what is happening but is there any way to Shield that wire downstairs because I can't move it - or I should say I'm afraid to mess with it (I've rebuilt amplifiers and repaired circuit boards but I only have a layman understanding)
I just wanted to add. After reading a thousand websites I did find people that had this ENF actually through all their plumbing pipes making the entire house a buzz trap for their guitars. They fixed it with a dielectric union but mine is just, seemingly, the ground wire.
Thanks for taking the time read
