- Tennessee NEC:2017
- Semi-Retired Electrician
I saw this on another Forum. Thought it would be a good discussion here.
Problem was on a new house where one 3-way circuit wasn't working right.
Power in one box with 12-2
12-3 ran from 1st box to 2nd box, white as the neutral, red and black as travelers
12-2 from 2nd box to light, whites/neutral tied together all the way from box 1 to light
Light works, but switch at 1st box doesn't turn the light off
Switch at 2nd box turns the light on/off, like a single pole
Switches have been replaced and problem still exists
A piece of 12-2 was ran between boxes as a test, only replacing the travelers as the neutral is good because the light does work
With the jumper ran, both switches work like they should
Now, your thoughts as to what is wrong?
