I understand the Code does not allow slash-rated breakers on non-neutral systems. Is the primary reason only that they have not been tested and listed for the higher fault to ground voltages.
It would seem that if the breaker can withstand a phase to phase fault, it would see the same situation in a phase to "ground" short.
