Theff
- North Carolina
- Electrical Contractor
Hello all,
Mulling over an upcoming job and coming to an item that has me concerned. The client is planning to install some stainless steel framing and strut supports. This is for esthetic purposes only. We are planning to run standard EMT conduit with standard EMT compression fittings. For esthetic purposes we were thinking of using stainless steel for strapping purpose to match the rack etc. Our concern is of course galvanic action. It’s not a corrosive environment, but there will be some moisture and humidity at times. Will the stainless steel straps in contact with the galvanized EMT cause problems down the line? What about the galvanized EMT in contact with the clients stainless strut? Straps and strut aren’t fittings, I guess.
There also are plans for powder coated steel enclosures to be mounted to a stainless steel frame. I know the codebook talks about powder coated enclosures when referencing dissimilar metals though. Just worried about the future and want a rock solid install.
Any experienced advice would be appreciated. Thanks
