Moonchava
New User
- Carlsbad, NM
- Contractor
Want to hear some feedback on bonding 400 amp split panel services for residential applications. The local inspectors are always changing their minds on what they want done and wanna hear someone else’s input. In one occasion they wanted the electrode conductor entering the meter can and bonding to the neutral here. Then isolating the grounds in the first panel and passing equipment ground with the 200amp feeder. Now they are wanting bonding in the meter can and the first panel but not installing equipment ground between meter can and first panel. On a separate instance the same inspector wanted the electrode conductor entering the first 200 amp panels and isolating ground and neutral at the meter can. Which way is the correct way?
