What is the best way to join 2" RMC, untreaded to 2 " PVC Schedule 80, unthreaded?
Installer
We're doing this in a remote area , on an island, and its going to be pretty hard to Bring a heavy pipe threader ou there.
Thank you in advance
That's just more steps for no good reason.
It's one extra cut of the RMC (assuming you're starting with full sticks threaded on both ends), and the substitution of a threadless coupling for a threadless connector. Basically using the threadless coupling to create a custom length piece of RMC, and then the female adapter to change over to PVC.
For better or worse it's the "correct" way to do it, as connectors are only designed for terminating raceways to enclosures.
Cheers, Wayne
