skorpioskorpio
- Georgia
- Engineer
I've always wondered what the logic was to making the default colors of larger gauge 2 conductor NM-B black and white? The only time I can see this being useful is if you were running a 120V only sub panel, which is pretty much never, or running a 30 or 50A 120V receptacles, which personally have never actually seen one in person. In almost all cases 6/2, 8/2, and for the most part even 10/2 will be used almost exclusively for 240V circuits, so why do the manufactures color code it for 120V?
...and on a related note, I've also always wondered why alternatively coded NM-B, in general, isn't a thing, regardless of gauge. I mean if you go to the trouble of making both 12/2/2 and 12/4, and 14/2/2 and 14/4 which are basically the same cables with 2 different color codes, why not just make a handful of alternate NM-B and MC /2 and /3 cables like Red/Black for 240V, Red/White and Blue/White and Red/White/Blue for alternates for 120V? Seems like this would be a win/win for manufactures as it would increase the number of variants contractors stock on the truck, with very little additional investment on their part, since they are making the components that would make up these products already. Not even suggesting they get crazy with it, just the most common color combinations that are used all the time in pipe and flex of black, red and sometimes blue. This would just largely eliminate the need to ever have to re-identify conductors for 240V or switch travelers.
Sorry, just seems like a really obvious product that just doesn't exist.
