ptonsparky
Tom
- EC - retired
That's a step up from A Sharp Stick. You must be serious.I'd rather stab my eyes out with a rusty nail than interact with that organization
Right but if a proposal has poor wording, they either need to modify the wording or reject it.
You'll have to cite me a code reference on thatBut, if you don't choose to try to make it better, then don't complain about it![]()
I think it is in the 1971 edition that a small town in Illinois still uses as their electrical codeYou'll have to cite me a code reference on that![]()
For that matter using the inspectors off the wall interpretation how's he letting the service disconnecting means get by?If the inspector interprets the definition to require GFCI's in the same room they should also be requiring AFCI's to be in the same room. Both are required to be readily accessible.
Be nice if they could go indoors right? Almost never happens on the farm. Commercial places with grain storage, it sometimes happens.Where would I put a panel at grain bins?
I agree there may be some vagueness there but also don't see anything stating it must be in same room as what is protected. Inspector still a moron.I was about to give my common "the inspector is a moron" response, but reviewing the definition, I think I have to agree with him, and instead place blame on the incompetent CMP's who can't come up with clear coherent non vague code articles and definitions.
Accessibility rules for AFCI's are pretty much identical as for GFCI's though. So A DF shouldn't change anything from this perspective.but I find it hard to beleive that no one uses DF breakers in this city.
Be sure and tell us how that goes.I'm pushing back on this for a number of reasons you guys have noted:
Sounds like a bunch of people just woke up from a 20 year napHey guys,
Just to close this out. I heard back from the building official who agreed that GFCIs at the panel were compliant although not something that is typically done in the area (there are many older houses and older residents). He mentioned that most of the owners expect the GFCIs to be on the counter and that's the reason for the initial back and forth. Most of the work in the area is just a kitchen or bath replacement and not a complete rebuild in place like we did and they like to ensure familiarity for the owner so I do kinda see the point.
Thanks for the discussion on the matter.
Dang, the bedroom lights went out again. Get my walker, umbrella and a flashlight maw, I have to go out in the bushes to check that dang breaker!there are many older houses and older residents
Well...................Dang, the bedroom lights went out again. Get my walker, umbrella and a flashlight maw, I have to go out in the bushes to check that dang breaker!
-Hal
Sounds like one of those inspectors that like to use the "the way I like it done" method of inspecting. They don't really have a code reason, just don't like the way you do it. I've dealt with a few of them.Hey guys,
Thanks for sharing.Just to close this out. I heard back from the building official
And in parts of the country you have to go outside to pee and poop.Well...................
In many parts of the country they would need to go down 2 flights of stairs into to a dark possibly wet basement.![]()
No, I definitely pushed the boundaries of what they were used to seeing, all the lighting is canless M2 and M4s from Nora, dimmers are Lutron Radio RA3 which e.g. requires separate occupancy sensors, there are contactors for patio heaters tied into the Lutron system and a few other oddball things here and there. There's also a ton of low voltage too. As long as I could back up what I wanted to do with actual code references and answer any questions intelligently, the building official and the few inspectors here have been easy to get along with.Did you get more discrepancies elsewhere?
You use Triac & ELV dimming, and teach a hard lesson for specifying LED without nuisance tripping xFCI.lighting is canless M2 and M4s from Nora, dimmers are Lutron Radio RA3 which e.g. requires separate occupancy sensors
