I am wiring my first in-ground pool.
There is a mixture of low voltage control stuff and line voltage(lights, mainly) that has been routed to a mechanical room. All the conduits come up in a way that would make the use of a gutter ideal. But I am wondering if all those wires can be mixed within that enclosure?
The insulation on the lower voltage stuff says 300v, for whatever that is worth. And the highest voltage equipment is 240v.
Did I read in another post that solar components can all be mixed together? If that is the case why couldn't the same be done for a pool? It is all part of the same system after all.
Thanks, any insight appreciated.
