Gear Q
Alwayslearningelec
NJ
Estimator
So where are terminating (10) 4" conduits in live 277/480 gear. Facilities is worried about vibrations and shavings so PM is asking for 6" KO cutter/punch and cup. We don't have one and are trying to avoid buying.
1. Why would 6" if you had to guess?
2. Really best way to do this with ko punch and cup? Any other way?
If the top panel of the gear can be removed, then you have other options for cutting the holes, including having a metal shop do them for you
Sounds like the PM is not planning on using conduits and with bus duct right above I can see why he would plan on chase nipples
