hbiss
EC, New York NEC: 2017
- Little Falls, New York NEC: 2017
- EC
I've had a Nitecore E4K LED flashlight for some years. See the link below. Seems that everybody that has one of these things, whether Nitecore or Olight, has a flickering problem. It goes out or dims and you have to shake it or bang it to make it work again. It's not that these things are cheap, I originally complained to where I bought it and they said to return it to the manufacturer IN CHINA. Google the problem and I get what I already know, keep it charged and battery contacts clean otherwise return it.
So, knowing that the only thing it can be is the battery contacts, but what to do? I tried cleaning both ends of the battery and end cap with an abrasive and that did help for a while. My feeling is that this thing draws a large amount of current when it is on high (it gets HOT) (battery is capable of supplying 15A continuously) and any resistance causes a momentary voltage drop that triggers the dimmer control to switch to another level. That's why it refuses to go to high if the battery charge is below a certain point.
Any ideas?
https://www.zoro.com/nitecore-e4k-next-generation-21700-compact-edc-flashlight-e4k/i/G401984470/?gclid=e21df943b2b61f4e41d9911940f6b256&gclsrc=3p.ds&msclkid=e21df943b2b61f4e41d9911940f6b256&utm_source=bing&utm_medium=cpc&utm_campaign=text_rlsa_dsa_na_na_shopping feed priority skus&utm_term=Flashlights&utm_content=Top 100k Impression Products $dsa
-Hal
Any ideas?
-Hal
