JimFromAustin
- Austin, TX
Quick background: Building new house in back yard. This new construction will receive power from utility. There can only be one meter (Austin, TX) The new house must have meter since its closer to transformer. The new house will then feed the existing house 100amps. The diagram is:
Utility--------> Meter --------> New House cutoff ------> New house panel
..................................................V
..................................................|------> Existing House cutoff -------> Existing house sub-panel
Power is supplied to existing house via PVC underground. Inspector is including bends not created by a machine as part of the 360 count. They are not factory bends. These bends are not dramatic, they are what the PVC will naturally allow.
Electrician says since this is a secondary line, these bends should not be counted. Who is right? You can see an example of one of the bends at the top of the photo.
Thank guys,
Jim
Thank guys,
Jim
