K&T wiring
Malywr
New Jersey USA
Customer wants to replace K & T wiring as much as possible. Can I splice K&T eires with Romax in the basement inside electrical metal box. I noticed there are multiple boxes in the basement with fuses protecting neutral 15A and hot 20A. Do neutral has to be protected with refuse in K&T wiring
Because if I use Romax on home run protection will be only on hot wire.
And
I would remove the fuses from the neutrals and use either a 15A GFCI or a combination GFCI/AFCI breaker.
