Alwayslearningelec
- NJ
- Estimator
no. just thought stainless or pvc coated would make more sense because of the raceway type.Are you thinking that a different material will last longer?
I would expect that the straps would be specified as PVC coated. Standard clamps will not fit correctly because of the increased outer diameter.no. just thought stainless or pvc coated would make more sense because of the raceway type.
Thank you. So you're saying a two-piece strut clamp won't fit? Can't be.I would expect that the straps would be specified as PVC coated. Standard clamps will not fit correctly because of the increased outer diameter.
Note this type of installation requires additional labor, training, and special tools to prevent damage to the outer PVC protective surface. It is also expensive. Some specs require that the installer be certified by the PVC coated conduit manufacturer.
Not properly, maybe if you changed the bolt to a longer one. But a PVC COATED clamp will fit properly and provide corrosion protection equal to the conduit.So you're saying a two-piece strut clamp won't fit? Can't be.
You might make the next larger strut strap fit, but if you really need PVC coated rigid, that strap won't last two years.Thank you. So you're saying a two-piece strut clamp won't fit? Can't be.
B-line regular rigid straps usually work for me. Sometimes just have the squeeze them a bit with pliers to get the nut started.Not properly, maybe if you changed the bolt to a longer one. But a PVC COATED clamp will fit properly and provide corrosion protection equal to the conduit.
-Hal
