jimzlyriks
- Henrico
- Retired electrician
Hi. I am a retired electrician, so I haven't taken a code class in a while. Is it code-compliant to run two 120-volt circuits to my outbuilding, which contains a roof and floor from my house panel. I have buried a 2" PVC conduit 18" + in the ground to house the conductors. Also, do the circuits need to be GFCI protected, and if so, how? With GFCI breakers or GFCI feed-through receptacles? Also, is it OK to run THWN or THHN #10 Copper conductors for the 120-volt feeds for the two circuits? The house panel is approximately 80' from the detached shed. Thank you for any help you can provide.
