- NE Nebraska
- EC
It isn't CMP members and who they work for as much as it is the AFCI and GFCI manufacturers have deep enough pockets to produce documents, demonstrations and such that are used to convince CMP members to vote their way when it comes to code making. While the contractors/installers that have different opinions on some the matter don't have any organization with deep enough pockets to produce similar opposing content and/or enough of it that is convincing enough to sway CMP decisions.There is at least one person from the appliance industry on CMP 2. Not sure if that person raised objections or not.
One appliance manufacturer on the CMP maybe does make them discuss things a bit more though. But maybe that person doesn't work for a manufacturer that is going to be effected by much or maybe doesn't make the appliances in question?
Before turn of the century most all GFCI requirements were there because of common real world incidents in certain areas and not so much one incident here or there that maybe had other code issues contributing to the incident. And a majority of them were 15 and 20 amp 125 volt receptacles being involved where it was common to see missing EGC pins on cord caps contributing to the problems. I was fine with a lot of the expansion of GFCI requirements involving 15-20 amp 125 volt receptacles for the most part.
One the first places they started to lose me at supporting most new GFCI changes was with the water drinking fountains and dishwashers. Most drinking fountains do have 15 amp 125 volt plug, but the receptacle is placed where it will be covered by the unit and risk of losing that EGC pin is not like it is with a lot of other equipment. I disagreed but not too strongly. The dishwasher wasn't even added because of compromised EGC reasons, it was added because of a component issue that potentially caused fires when it failed and it was discovered that GFCI would trip when that component failed. I never really knew exactly what component was, but IMO this issue should been resolved with product recalls and not by code requirements. After that they started going hog wild with added GFCI requirements with no real justification for them. And I believe the official reason for some the first three phase GFCI protection requirements was something to the effect "we now have that ability" and not something like "there has been quite a few shock and electrocutions incidents involving this".
