Wall Type
Alwayslearningelec
NJ
Estimator
Not typical detail that shows the insulation but does reference mineral wool. Does this look like a wall that could recess a receptacle box?
I've never seen these horizontal "plates" within CMU before. Would this prevent electrician from running conduit vertical within thus having to surface mount? They do have vertical rebar within so IDK.
They're not plates they're Durawall very common in block construction.
Durawall or a similar product does not block the actual cells of the block so a raceway can be run within the wall and the box is flush mounted with the face of the block in the wall. You can see the Durawall above the box as well as the vertical rebar.Box in Block Wall.jpg
