Dfw high voltage
2 nd year apprentice in Dallas learning the code
- Dfw
- Electrician
Hi, my name is Brandon a 2nd year apprentice . I’m working on a restaurant project and need some help with lighting questions. I have a PNL B 120v/208 wye 3p 4w where ckt- 29 feeds a 120v Tork EWZ201C time clock. That time clock has 2 channels what I’ve seen, it will control two separate contactor panels, which switch lighting and equipment on and off based on the programmed schedule. I want to install an override switch at each contactor panel so I can manually turn them ON or OFF at any time, regardless of the time clock. What’s the proper way to wire the Tork time clock and the two override switches to make that work?
I have a drawing attached I don’t believe that I’m 100% right but I hope I can get the help I need https://drive.google.com/file/d/1Km6dfuyt6UhSzszUzRxMSCyZKvZB_tME/view?usp=drivesdk
