Alwayslearningelec
- NJ
- Estimator
The notch and bolts used to bolt the sections together come with the equipment? I'm assuming not. Thanks
Yes it comes with the gear. The bus sections may use special hardware like Belleville washers which the gear has been tested with. Eaton gear uses carriage bolts to connect the cabinets together.The notch and bolts used to bolt the sections together come with the equipment? I'm assuming not. Thanks
Thanks..sometimes I believe the lugs DON'T come with transformer??All of the switchgear that I've put together does come with hardware supplied. Transformers never do so you always want use grade 8 bolts when securing lugs to transformers.
They may or may not come with lugs, typcially they don't. Depends on who's supplying them and how they're ordered.Thanks..sometimes I believe the lugs DON'T come with transformer??
