Jpflex
Electrician big leagues
- Victorville
- Electrician commercial and residential
where a luminair canopy or pan exceeding installed within combustible material finish exceeding 180 in sqr around the canopy or pan edges, ahall be covered with non combystible material
What exactlt does this mean
Is NEC saying that luminairs and pans must have a void space around it exceeding 180 sq inches if nearby finish ( wall ) is combustible?
In contrast flush mounted services require no such gap greater than 1/4 inch between itself and finish surface
Also do you put calking around the pan to meet this requirement or what material do you use?
Never seen anyone enforce this code?
