Adding in a sub panel for an addition. Currently there is a 200amp ATS main that goes to a junction box. Using Polaris connector there is 100 amp house panel tapped off this 200. The 200 continues to feed 200amps to garage. The 100amp house panel has some room but wasn't enough for addition. The house panel currently has a 60amp feeding another sub panel in the barn.
My question is should I go off the 100amp house panel with another 100amp to feed addition? Or use 4 port Polaris connector and come right off 200amp feed.
I'm currently leaning towards tapping off the 200amp main but wanted to see if others had opinion on it.
Thanks
Thanks
