Talking about a fire pump with a controller/transfer switch. I know that a fire pump is usually set up as its own dedicated service or a tap ahead of the main. Being a service, I also know that the feeder tap rules do not apply. From what I can tell about the stand-by generator connection, it allows for a breaker sized to handle the motor starting but doesn't explicitly require it. The question is, does the connection directly at the generator qualify as a feeder requiring it to be subject to the feeder tap rule distances?
