The water would have to be 4' deep in my basement before power to the VFD became an issue.True in that use case, but during maintenance, both well and sump pump areas bexome wet if you disconnect piping.
There is a difference between outlet and receptacle in the NEC.Wouldn't it still be considered an "outlet"?
My cousin called me last week. One of his relatives is building an addition and they are installing a new well. The Well Co is on site and they hit good water at 130 feet. They are using a submersible with a VFD control so I guess no pressure tank is needed as the pump ramps on the VFD to control the pressure. The house is on a mountain top that gets lightning. The house has lightening protection.
Anyhow, the well company has the pump installed but no wiring yet so they had a generator and were trying to run the pump off the Gen and it wouldn't work they wanted to test the well.
I told him a lightning strike or if they loose power (which they do) and go on their gen they my not play nice with the VFD. i would go with a pressure tank and a switch but that's just me.
The well installers were complaining about their boss who loves the VFDs.
Agree. But they have an old portable gen.My VFD well has had no problems on my Generac whole house generator.
Me too. Retiring at the end of this month. Tired of the constant changesGlad I’m retiring, the NEC is getting ridiculous! Everytime a storm comes up, the gfi will trip.
Article 100Need some help, Inspector is requiring all well pumps to be GFCI protected. Sighting 210 8 (F) in the 2023 NEC code. This code only pertains to a receptacle, not a well. He claims it is utilization equipment. The code will at some point make a well pump GFCI protected but as of right now it is not required to be GFCI protected, please give your argument either way because I believe the building department is mis interpretating this code.
210.8(F) would apply to a well pump. You are providing an outlet for electricity to utilization equipment located outdoors.
what about 210 .3 where it refers to 430 for motors?210.8(F) would apply to a well pump. You are providing an outlet for electricity to utilization equipment located outdoors.
motors are governed by 430, isn't a well pump a motor?what about 210 .3 where it refers to 430 for motors?
In the 2014 and older codes, nothing in 210 applied to motor circuits as the scope said:what about 210 .3 where it refers to 430 for motors?
In the 2017 and newer codes, the rules in 210 apply to motor circuits unless modified by rules in 430. Nothing in 430 modifies 210.8(F).210.1 Scope.
This article covers branch circuits except for branch circuits that supply only motor loads, which are covered in Article 430. Provisions of this article and Article 430 apply to branch circuits with combination loads.
They still have a small tank for expansion reasons, water won't compress and pressure will change too rapidly if there is no expansion tank.My cousin called me last week. One of his relatives is building an addition and they are installing a new well. The Well Co is on site and they hit good water at 130 feet. They are using a submersible with a VFD control so I guess no pressure tank is needed as the pump ramps on the VFD to control the pressure. The house is on a mountain top that gets lightning. The house has lightening protection.
As with all GFCI rules, it should not apply to hard wired equipment.I think NEC needs to re-evaluate 210.8(F).
+1Glad I’m retiring, the NEC is getting ridiculous! Everytime a storm comes up, the gfi will trip.
I'm in agreement with the hard wired equipment shouldn't need GFCI protection. Art 680 applications may be about the only exception to that.As will all GFCI rules, it should not apply to hard wired equipment.
Associated with a dwelling.What happens if you build a well house over the well? It is then indoors, and not a dwelling.
