WAGuy58
- Edmonds, WA
- Contractor
I have a client that wants to add a solar powered light inside a shed 200+ feet from his house. He doesn't want to run a line to the shed. The shed doesn't have any windows and it is fairly dark during the day time which makes it difficult to locate smallish items on the shelves. He wants to be able to put a mechanical spring timer (15 min) inside the shed so he can turn the light on during the day and have it turn off automatically so it doesn't run down the batteries and leave the unit in an uncharged state.
Most solar outdoor/shed lights are motion activated and also have a photoelectric switch (PE) so that the light only comes on when it is dark outside. These units mount the PE switch on the solar collector unit which is mounted outside of the shed -- allowing it only to be operable at night. They incorporate the PE switch because they use 18650 lithium batteries which can get damaged if they are being charged and discharged at the same time. This is another reason why they put the PE switch outside.
Is there any such thing as a mechanical timer with two load terminals. with load 1 being continuous continuity (ie. in the battery charge state) until the timer is activated which switches the continuity to load 2 (the light)? The two loads must be mutually exclusive - essentially a SPDT switch.
