Flickering lights during washer usage
As of this writing, there is no known solution for flickering leds, phantom tripping of afcis, appliances randomly interacting with each other like they are possessed by evil spirits, and so on and so forth.
Your washer will trip the GFCI behind your brand new fridge, which will make the bathroom lights flicker, which will start the well pump. There is no solution besides a return to 1980’s tech.
Or 1880’s. 😳
I can only repeat my own experience here. I had a 1929 house with a 1929 fuse box at 60 or 100 amps. I'd run the washer, and the incandescent lamps throughout would rock and roll to the agitator. I finally had an electrician install a new panel, moved the washer to a dedicated outlet in the basement and the problem went away. That is all I have on the matter.
Can the customer do laundry during daylight hours when lights are not needed? 😉
Apples to oranges.
I pigtailed a 60 watt incandescent and a dimmable 5.5 watt LED to the end of 75 of extension cords. A small Drill Press was used as a load at the same device as the cords. Cycling the DP caused a noticable flicker in the incandescent. Nothing in the Sylvania LED.
